Transmission height 1200 coupe
Quite a regular
Hi, i was wondering if someone could measure the height of the output shaft or a 1200 trans from the top of the tunnel ?
Because the previous owner of my car had an 63A 5 speed trans (I supposed) and removed the trans support from the tunnel. Now i have to make new one since he sold the 5 speed and when i bought the car it came with the oem 4 speed.
I have to make new mounts and bolt them inside of the tunnel, i want to be sure i put it in the perfect height.. So if someone could take or have the measurement that would be sweet.. I have an automatic tunnel so would love the measure from an auto tunnel in case the height is different and from the top of the tunnel to the center of the output shaft..
Thanks you very much !
Posted on: 2016/10/25 20:43
Re: Transmission height 1200 coupe
Quite a regular
Up
Posted on: 2016/12/11 14:28
I am in the same situation in my ute project. Can someone measure ute manual transmission tunnel too?
Posted on: 2016/12/11 14:51
Few of us (if any) have automatic tunnel with 4-speed installed
Best way is to measure the gearbox angle. It should match the diff pinion angle. Get the gearbox level (with the pinion) then fix the brackets in place
jpg  23850.jpg (34.31 KB)
174_584dbce43fed8.jpg 752X336 px
Posted on: 2016/12/11 20:54
Measure using angle-master, inclinometer or protractor
$22 at Sears: sears magnetic protractor
jpg  First measure pinion angle.jpg (124.91 KB)
174_584dc08faa969.jpg 1280X752 px
jpg  then lower or raise gearbox to match.jpg (40.63 KB)
174_584dc09bf350c.jpg 600X400 px
Posted on: 2016/12/11 21:12
Quite a regular
Thats a really good idea, thanks !
Posted on: 2016/12/11 22:46
Genius
Posted on: 2016/12/12 23:03
