MadDat Front sway Bar / adjustable billet lower control arm help need it
From St. Louis, MO
Hello guys,
Need some help with some MadDat parts I bought.... of course I have email message them but with no help...
I bought theirs billet lower control arm and their Rotary conversion kit . Since they can't provide any instructions or pictures, would like to know if any of you have done thie swap and have any pictures how does the sway bar gets install. Sounds stupid but the one they send me doesn't seems to fit.
Thanks in advance
Posted on: 2016/12/30 17:41
Edited by DogoX on 2016/12/31 0:12:12
Re: MadDat Front sway Bar / adjustable billet lower control arm help need it
It goes in same way as the stock bar. The difference is the links it uses
Mad Dat
Mad Dat end-links have the topmost end turned 90-degree to match the swaybar hole
jpg  Stock end-links.jpg (7.27 KB)
174_5866e1567542b.jpg 77X224 px
jpg  90-degree end-links.jpg (13.58 KB)
174_5866e15f42dac.jpg 242X395 px
Posted on: 2016/12/30 22:26
Both LCA have same connections. The Mad Dat unit is adjustable in case you want to change camber and don't have camber tops
jpg  1200 stock LCA.jpg (32.90 KB)
174_5866e81325cbf.jpg 560X249 px
jpg  Mad Dat LCA1200.jpg (62.22 KB)
174_5866e8993067c.jpg 700X449 px
Posted on: 2016/12/30 23:07
From St. Louis, MO
Thanks but I have the bullet and is different than the one you post
Posted on: 2016/12/31 0:10
Puerto Rico! Home of the fastes Rotary engine cars! Period
From Rosewood, QLD
still has the same holes mate
Posted on: 2016/12/31 0:55
1971 B110 sedan project.
2012 Nissan Micra daily.
Yes, same 5 holes
As expected this is the same LCA used by 1200, 120Y, B310 Sunny/210 and A10 Stanza. I reckon it means it requires the late Ball Joint, instead of the original B110-type (H10) Ball Joint
jpg  Mad Dat LCA1200B (billet).jpg (37.72 KB)
174_5867428a7c48a.jpg 848X320 px
Posted on: 2016/12/31 5:30
Here's the Mad Dat anti-sway bar and Mad Dat end-links installed
jpg  SWB1200.jpg (49.38 KB)
174_586747ce47981.jpg 700X450 px
jpg  A3716A0E-908E-4E80-9BBE-EB10FE7224A8-150-0000000436A7C59E.jpg (100.27 KB)
174_5867481f43668.jpg 768X1024 px
jpg  656E7006-0942-4616-8894-A0F2141D5B90-150-000000043D2F6A60.jpg (67.78 KB)
174_5867482914ded.jpg 768X1024 px
Posted on: 2016/12/31 5:56
