Browsing this Thread:
1 Anonymous Users
Re: Datsun 1200 Sedan Build |
From Trinidad and tobago
took her to another island
Posted on: 2015/5/3 4:11
'71 Four Door Sedan. A15 Engine + Lighten Flywheel. E15 Electronic Ignition 32/36 Weber EI Coil 4 into 2 into 1 Extractors 1 3/4 Exhaust Pipe Semi Flow Hotdog 60 series Gearbox H150 Diff.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Not too shy to talk
where did you get your lighted flywheel from?
Cheers
Posted on: 2015/5/3 10:09
Its not a lighten flywheel its from the A12.
Posted on: 2015/5/25 4:41
Street Sleeper!
I'm still here folks!!
Posted on: 2015/9/28 21:42
Street Sleeper!
Well am back, was out of the scene with the datsun for some months gone, i have did some updates on the car but didn't get time to post the pics on here! So i'll kick it of again!!
Went and purchased a new MSD Blaster coil 3 i didn't get the blaster 2 as what i'm used to be seeing on the a series engines, i mounted it in the original spot but i left the other aftermarket coil as is here are some pics
Posted on: 2017/1/10 2:27
Street Sleeper!
After getting the blaster coil all hooked up and running,the plugs burn cleaner and gets a efficient start up from cold,my plug wires are 8mms so the they are good to go. Few weeks later i went to put on some rubber, took off the 205/60/13's and now running 175/70 13's so it have a stretched look with the 7'' wheels
Posted on: 2017/1/10 2:47
Street Sleeper!
update
Posted on: 2017/1/11 1:17
Street Sleeper!
Swap back on the original 1200 springs from the 120y ones as they were higher , now she sits a bit lower, took it for a drive now my exhaust is touching. more ti come!
Posted on: 2017/1/11 1:22
Street Sleeper!
Registered Users Contentmaster Usermaster
What are the green springs? Are they new 1200 springs?
Posted on: 2017/1/11 1:35
The green springs are the original springs the car came with but just all cleaned up and painted
Posted on: 2017/1/11 2:01
Street Sleeper!
