Adjustable Camber
From Trinidad and tobago
I want to use s13 camber top plates on my 1200 will the stock spring and top perch fit with out any other adjustments?
Camber plates shown in the pic
Posted on: 2017/1/9 1:49
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: Adjustable Camber
Yes, unbolt the stock Strut Top, then bolt the T3 Top. You may need an appropriate top nut depending on which strut inserts you have (diameter of strut rod). Datsun 1200 uses M8 studs, if these Tops use M10 studs you can file the strut tower bolt holes. T3 can provide more details via email
If you use the stock large-diameter springs, you will get minimal camber adjustment. The camber will adjust about 1 degree before the spring hits the side of the strut tower. If you want massive camber, go with small-diameter springs
jpg  T3 Camber Plate for Datsun 1200.jpg (27.86 KB)
174_58730849521cb.jpg 464X360 px
Posted on: 2017/1/9 3:46
I have these in stock and I'm in Australia and willing to ship
Posted on: 2017/1/10 1:00
Car free
So all I have to do is remove my top strut hat an replace with th s13 ones
Posted on: 2017/1/16 14:44
Street Sleeper!
T3 sells 1200-specific tops. S13 tops require filing out the strut holes (S13 tops have M10 studs, 1200s have M8 holes)
Posted on: 2017/1/17 3:23
To fit the camber tops to your stock springs and shock you need a domed washer between the spring hat and the spherical bearing in the camber top to prevent it binding. I had to use a spacer too in my old b110 too.
Posted on: 2017/1/17 11:13
Does this kind of top nut come with the T3 Tops?
jpg  spring assembly.jpg (43.46 KB)
174_5880597e1f7b6.jpg 400X1276 px
Posted on: 2017/1/17 21:05
Edited by ddgonzal on 2017/1/19 6:15:35
YES THEY DO!
so the T3 will bolt straight on the stock springs, i just really wanna clarify
Posted on: 2017/1/17 22:49
Street Sleeper!
Yes, camber tops will work with stock springs
* You may need a spacer and domed washer
Posted on: 2017/1/17 23:05
There are different kinds
spacer above Spring Cup (can use stock Spring Cup or alloy Spring Cup)
adapter for small-diameter strut to large pillowball
Use stock rod nut
OR, use a spacer with a special pillowball top nut (like these Cusco tops)
jpg  Pillowball Nut.jpg (47.93 KB)
174_587ea75731737.jpg 600X704 px
jpg  Maddat 1200 tops with spacer-adapter and rod nut.jpg (15.60 KB)
174_587ea8ab54fde.jpg 255X240 px
Posted on: 2017/1/17 23:23
