Idle up solenoid for thermo fan operation
From Sydney, NSW
Hi just wondering if anyone has implemented an idle up solenoid for acpurposes or when the fan kicks in on a stock carb? Thanks
Posted on: 2017/2/7 6:49
Re: Idle up solenoid for thermo fan operation
Yes, Datsun did. It is about the Aircon compressor and not directly related to the fan
The magnetic switch is on the side of the compressor, and opens when the compressor activates
Fast Idle Control Device FICD raises the idle speed automatically when A/C is ON to respond to the increased load of the A/C compressor
A15 models were like this:
A12 (1990-1994) used an electric solenoid
Posted on: 2017/2/7 8:03
Also note that most models with A/C didn't have idle-up because It's not needed. You can just set the idle 50 rpm higher than normal. Then when A/C kicks on it goes down to normal. For emissions control it's more important that the idle doesn't vary and is set to the least emissions. So the 1990 Japan emission used it, as did the 1979 USA models
Posted on: 2017/2/7 8:14
From Sydney, NSW
They seem to very much be a USA style ring but new they're like $120 which is rather crazy! Oh to be at a 70-80s us wrecker
Posted on: 2017/2/7 19:47
From Sydney, NSW
I can imagine the stock datsun item would be hard to find? Have you seen one in your travels David?
Posted on: 2017/2/12 21:01
From Sydney, NSW
This looks like it could work pretty well
http://s.aliexpress.com/MV3iARN7
Posted on: 2017/2/12 21:28
Yes, stock Datsun item is uncommon, but I have seen them. I don't know what that "diesel stop solenoid" is for
Posted on: 2017/2/14 2:43
From Sydney, NSW
All good I was thinking I might remove the dashpot thing if that doesn't impact smoothness all too much and replace it with an electronic idle ac up solenoid...
jpg  16587299_10155059418598140_4905987389583348010_o[1].jpg (144.27 KB)
12667_58a27429a9041.jpg 1536X2048 px
jpg  16730209_10155059416133140_3948034412970922086_n[1].jpg (17.70 KB)
12667_58a2744b11d84.jpg 480X286 px
Posted on: 2017/2/14 3:05
From Sydney, NSW
I can't seem to find a model number or markings on the carb to order a rebuild kit? I'd love to redo the gaskets etc.
Posted on: 2017/2/14 3:07
A-series Hitachi carbs have an inked ID. Once the carburetor is "cleaned" there goes the ID
Post photos of all four sides and we can ID it for you
Posted on: 2017/2/14 3:43
