4-5 STUDS
From Nyngan, nsw Australia
hi how easy is it to change from 4 to 5 stud, looking at more options to wheel selection
Posted on: 2017/2/16 8:00
living is good,.....
Re: 4-5 STUDS
Very easy ...
Posted on: 2017/2/16 9:50
Re: 4-5 STUDS
Yeah don't think that will pass here in Australia
Posted on: 2017/2/16 20:26
Re: 4-5 STUDS
The next easiest way to is to redrill the hubs & axles. However the 1200 front hubs and most Datsun hubs are optimized for light weight and so there isn't enough metal to redrill them for example this Stanza hub look like you could redrill them
until you turn it over, and see there is no space for drilling a new PCD
So you could change the struts. S14 struts with the 5-lug hubs (5-on-114.3) will work on a 1200
Dunno if the rear axle flanges can be re-drilled. If not you can swap the rear axle assembly, e.g. use a shorted Falcon rear (5x114.3) or something
Posted on: 2017/2/16 22:51
