Ca20 throttle body
From Kelmscott Western Australia
Anyone got a ca20 throttle body twin butterflys at all
Thinkin of just big bigger flow in my efi :)
Posted on: 2017/3/21 11:41
Re: Ca20 throttle body
Up to the top
Posted on: 2017/3/27 12:36
71 Datsun 1200 ute with A14 fuel injection and T50
59 Morris minor ute with A15 fuel injected with intercooled turbo
Yes the CA20 throttle flows more air, and (reportedly) bolts onto the A14 manifold with only a "little modification" needed
You can also fit a single butterfly throttle -- which will flow even more air. The twin-butterfly design I would guess is used to enhance the vacuum signal in the smaller channel. Frank used a 55mm throttle from a CA18
compare to the stock A14E twin-throttle body
Geoff thought 55mm gave poor throttle response (all or nothing)
Neal used a GA16 throttle body
Michael used Camira throttle body
Posted on: 2017/3/28 6:42
Bump
Posted on: 2017/3/30 13:00
Bump
Posted on: 2017/6/24 11:26
