« 1 2 (3)
Re: How to use AE86 LSD in Ute
As per the wiki says t series fits if you drill and tap the housing. Do axles fit t series diff? Not sure I'd machine it to fit a h165 snout
Posted on: 2017/4/14 9:39
There are two wiki articles:
* Using AE86 LSD in H165 differential
* Using AE86 differential in H165 housing
Posted on: 2017/4/15 5:17
Quite a regular
From Christchurch, NZ
"As per the wiki says t series fits if you drill and tap the housing. Do axles fit t series diff? Not sure I'd machine it to fit a h165 snout"
H165 axles fit T-series diffs.
"*** All machining was very minimal and done professionally. As there was concern over removing material and creating weaknesses we looked into the safest and most functional way to achieve the strongest most reliable result worth the effort***"
Theres no weakness created from the machining we did to fit the AE86 LSD centre.
I guess I need to find all the info to prove it.
In the meantime heres some physical proof of the machinists personal work, his own car showcasing his talents throughout:
Yes, a one-off self-designed and self-built entire itb setup for his VH41...
Posted on: 2017/4/17 2:04
« 1 2 (3)
