« 1 (2)
Re: rotor size for brakes up grade
From Sydney, Australia
Hey Rocket
Did you bench bleed the master cylinder before installing
They normally don't bleed very well if just installed straight on the car.
Might help to remove the master and try that.
Also if going disc front and rear.
Selection of the correct size master cylinder, will alter pedal effort and amount of travel.
To get the right amount of hydraulic advantage for your setup
Posted on: 2017/4/23 9:46
From Nyngan, nsw Australia
yeah I also was thinking that the rod coming out of the booster was not long enough, so I adjusted right out still no different, plus something I never asked maddat if there setup would suit my brakes...you'd think it wouldn't be that hard surly lol
Ill try the bench bleed it tomorrow
Posted on: 2017/4/23 10:07
Edited by hotrocket on 2017/4/23 11:53:43
living is good,.....
Well the bench bleed might help
the pushrod needs to be exactly the right length.
Too long or short.
Can both cause problems.
A quick Google search.
This article will explain it will explain it better than I can type.
http://www.mpbrakes.com/techtalk/how- ... in-to-master-cylinder-gap
What size master did you get from maddat?
Posted on: 2017/4/23 13:32
What will cause pedal going to floor?
Check if it is the booster: disconnect and plug the vacuum line at the manifold. Pump the brakes until vacuum is used up. Now is the pedal high and tight?
Posted on: 2017/4/23 19:45
will be checking the rod length and booster
Posted on: 2017/4/23 21:36
« 1 (2)
