200b struts Commodore tubes
Not too shy to talk
From Victoria, Australia
Converted my 200b struts to take Commodore strut tubes. More pictures soon!
Posted on: 2017/5/21 1:39
Re: 200b struts Commodore tubes
From gold coast QLD australia
Thats one way of many systems used.
I have been using that system on my coupe for 10 years and on other cars i have built. Resonable price as well.
Posted on: 2017/5/21 4:22
GO RACING,GO HARD OR GO HOME!!
SLY OLD FOX..................
Not too shy to talk
...having no end of grief trying to upload resized iPhone images....
Posted on: 2017/5/21 11:08
Email me the pics I'll post them.
Cncplastering@hotmail.com
Posted on: 2017/5/21 11:24
Car free
Not too shy to talk
Thanks Nick, pictures sent. Commodore tubes were cut out, the stubs were bored out in the mill and lathe. I TIG welded them in the lathe to make sure they were aligned (I made sure not to earth through the lathe bearings).
The stubs were hard to machine around the old weld effected area.
The conversion allows the use of 36mm Bilstein Commodore inserts as opposed to 30mm inserts from vehicles like early VW Golf etc.
The bigger piston shocks don't overheat as easily as smaller piston shocks during a rally stage. Shocks are best if revalved such as those that Stuart Wilkins sells.
Posted on: 2017/5/24 11:02
Here's your pictures. But of work in them
Posted on: 2017/5/25 14:39
Car free
From RSA
I've always wondered why nobody does the shocks like that --less problems
Posted on: 2017/5/25 16:38
I do, but I use base height adjustable stuff. Can get valves and spring rate changed to suit application too
Posted on: 2017/5/26 3:07
Car free
Not too shy to talk
Base height is definitely the go if you can get inserts to suit your application. I nearly adapted some S13 base height adjustable coilovers for better preload and corner weighing setup, but the majority of shock inserts would blow during a long rally stage. 36mm Bilstein inserts will do quite a few rallies between rebuilds. With a passenger of similar weight corner weights a less of an issue, and preload should be 'OK' if springs are at least captive.
Posted on: 2017/5/26 10:21
