Steering column and box
From Goulburn NSW
Hey guys,
is the steering column and box in a 79 ute 3 speed or 4 speed?
Posted on: 2017/10/4 9:27
Re: Steering column and box
3speed gearboxes were only fitted to some STD 1970-1973 Datsun 1200s. The column used with a 3-speed has a column-shift mechanism attached instead of the floor shifter which the 4-speed uses
column-shift column
Posted on: 2017/10/4 11:20
From Goulburn NSW
Thanks DD I thought the speed was something to do with the how many turns from lock to lock of the steering wheel.
Posted on: 2017/10/5 2:30
From Goulburn NSW
Hey guys,
does anyone know how long a steering column and box usually lasts for?i have checked mine and there is no play and nothing looks worn in the box.
Posted on: 2017/10/10 7:01
Usually last the life of the car. My last sedan was 40+ years old and still working, though with a little play in the wheel (35mm instead of the brand-new 25mm play). My first 1200 did 400,000 km and 28 years old with about the same amount of wear
Posted on: 2017/10/10 8:49
