HELP need NON-USA B310 wiring diagram
From Little Rock, AR
Hey guys, I'm looking for a late model (81-82) non-USA B310 wiring diagram. I've already got a North America wiring diagram and need to look at one from a different country. I'm going to be installing a JDM B310 instrument cluster and want to match up the wiring on the back. Most of the wire colors are the same but there looks to be a few differences in wire colors on the clock, and I want to make absolutely sure the others are all correct too.
In case you didn't know, Nissan wired the instrument clusters up much differently between different levels of trim (tach/non-tach/US/non-US). So if you ever plan to swap out your cluster, you'll have to do some repining of connectors and wire in some other ones; it is not plug and play. It even looks like the non-US versions had a little light that shines thru the ignition key surround too, but I don't have that piece, just the wire that goes to it from the instrument cluster.
Any help will be greatly appreciated! I'm probably going to go out to the garage and start working on it here shortly. Pulling the instrument cluster isn't difficult, but it is difficult to do without breaking things on B310s.
Posted on: 2017/12/30 16:54
Re: HELP need NON-USA B310 wiring diagram
Come on you aussie blokes! Doesn't anyone have a B310 wiring diagram?
Posted on: 2017/12/30 21:10
Posted on: 2017/12/30 21:47
Edited by unfamilia on 2020/3/29 12:46:47
I figured it out without the diagram, but still wouldn't mind having a copy of the wiring diagram when you get a chance. My B310 manual came with a full page foldout of the entire diagram, with wire colors and everything, that's more or less what I'm looking for. Thanks!
Posted on: 2018/1/1 3:13
Posted on: 2018/1/1 5:15
Edited by unfamilia on 2020/3/29 12:45:54
Thanks!
Posted on: 2018/1/1 12:43
