ELECTRIC FAN ON A15
From Trinidad and tobago
Hi all i have an A15 and want to install a electric fan, its a 12 inch fan Nissan b11 thermo switch with 2 pins, and a relay an looking for a wiring diagram or could someone point me in a direction, any help would be greatly appreciated..
Posted on: 2018/2/5 1:52
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: ELECTRIC FAN ON A15
Stock A15 fan provides better cooling:
* 12.2" diameter
* always on
But the B11 fan will cool OK, it was used on 1.5 liter E15 engine
* fit the thermo switch in lower radiator hose
* Power fan with direct connection to battery + and - (use a 10A fuse near the battery)
* an inexpensive 85/86/87/30 relay or a 4-pin Nissan relay
* Switch power on/off using the thermo switch and + wire off the coil 12V (Ignition voltage) -- it won't affect coil since it is a low-current switching signal (the fan itself it powered by battery + )
jpg  ThermoFan.jpg (16.34 KB)
174_5a77e13f47796.jpg 786X478 px
Posted on: 2018/2/5 4:44
Were does the other wire that states ignition goes, Does it go to the ignition switch? if so what pin?
not to verse in electrics
Posted on: 2018/2/20 23:05
Street Sleeper!
wire marked IGN can be connected to any wire in the Ignition system. I recommend the Coil + wire (or the 12V + side of the Ballast Resistor) -- because its a handy engine compartment location. The relay steals almost no power from the coil so it's OK to do it
Or, some guys run a new wire to the Fuse Box and connect it to one of the IG terminals
Posted on: 2018/2/21 5:04
