New Nissan A series camshaft - USA
From Seattle ,WA.
Hi all, been ages since I've been on the site. I need to pul the A15 apart again to replace the Delta Cams regrind shaft, lobe went flat again. I'm wondering if I can buy in the US a brand new cam from Nissan? All the old links I had seem to of dies - nissanparts.cc, cant remember the Vancouver BC dealer, can anyone recommend a Nissan dealer that'll chase old parts?
Thanks,Evan
Posted on: 2018/2/26 2:30
Re: New Nissan A series camshaft - USA
Younker Nissan -- at least in 2013 -- had a veteran parts counterperson who could find Datsun parts. I was told that Campbell Nelson Nissan also was helpful
Posted on: 2018/2/26 8:13
Look like the good A14/A15 (6000 rpm) cam is still available 13001-H6200
The 5600 rpm A15 camshaft is discontinued 13001-H9800
The higher RPM Nissan cams were only available in USA via Nismo, and appear to be discontinued
Also get new lifters (or have the old lifters refaced) then use cam assembly lube and run the engine for 20 minutes at 2000 rpm (don't let it idle until the lifters/cam lobes wear in)
Posted on: 2018/2/26 9:23
From Seattle ,WA.
Hey david, how the balmy Hawaiian weather :)
how'd you figure out they're available, you have a website that shows available vs. discontinued?
It looked like Tomei still sells A series cams, other makers sell aftermarket stuff for for the L series motors and Z car stuff but A seems hard to find. I thought this time I'd throw a stock cam in. The delta regrinds seems to fail, I adjusted the rocker to 12 thousands when warm, ran it for about two mins and rechecked it , was .016 - .017, gained 5 or 6 in minutes. cam/lifer face grinding away....
Posted on: 2018/2/27 4:55
Yes, the websites of various Nissan dealers show availability. Click the links in my previous message to see which are marked "discontinued" and which are still available. If the part is superceded it will list that too
Posted on: 2018/2/27 8:17
From Seattle ,WA.
figured that out after clicking on one of your links, thanks
Posted on: 2018/2/27 15:52
From Seattle ,WA.
cams I have - profiles from Delta, thoughts on using them..
KC grind that failed
.330 - .331 lift ?
.502 & .526 lift
Posted on: 2018/2/27 16:17
From Seattle ,WA.
guess I have to re-learn how to post pic's properly but you get the gist.
anyone make sense of the cam sheets?
Posted on: 2018/2/27 16:20
