Strut knuckle arm info needed
From Goulburn NSW
Hey guys,
I'm looking at starting to get all my front end sorted soon and will be going with 200b struts,will the 1200 knuckle arms fit the 200b struts?
Cheers.
Posted on: 2018/4/29 10:24
Re: Strut knuckle arm info needed
Posted on: 2018/4/29 10:55
Edited by unfamilia on 2020/3/29 12:32:01
From Goulburn NSW
I haven't actually got them yet just want to know which ones to buy.
Posted on: 2018/4/29 11:04
* No 1200 knuckle arms take the large struts
* You may use the A10/B310.A14+A15 knuckle arm
Mating the knuckle arms to the LCA is done via ball joint: Use 1976-1985 B120/B210/B310 LCA/tension rod and A10/B310 ball joint. For more details, see SAP
Perhaps the 200B knuckle arms will also work:
* if it fits the ball joint
* if the tie rod end fits into it
The A10/B310 "W50" knuckle arms is a known fit and accepts struts with 80mm bolt spacing
Posted on: 2018/4/29 11:28
From Goulburn NSW
Hey guys,
thank u for the info.I have looked at the link that DD gave me(SAP) and can anyone confirm that these are the wright part numbers for the W50 knuckle arms as per the pictures under W50
40052-W5060 Right side
40053-W5060 Left side
Cheers.
Posted on: 2018/5/1 11:46
