Browsing this Thread:
1 Anonymous Users
ajustable timing gear |
From WA perth
can you buy just the adjustable timing sprocket, I know you can get the whole lot witch I already have on my motor
Posted on: 2018/6/20 12:12
Re: ajustable timing gear |
Registered Users Contentmaster Usermaster
Yes you can buy the adjustable cam sprocket alone, instead of as part of a complete timing chain set Bprojects Racing Timing Adjustable Cam Gear
Posted on: 2018/6/20 20:05
Kameari cam sprocket about $170 USD KAMEARI SKU: 57447 Type: Fully Adjustable Material: Chromium-molybdenum steel Included: 1 gear
Kameari 57447.jpg (38.85 KB)
Posted on: 2018/6/20 20:12
Posted on: 2018/6/20 20:27
Posted on: 2018/6/20 20:34
From WA perth
I know you can get the whole lot my sprocket is warn out and need a new one with out buying the whole lot
Posted on: 2018/6/21 8:51
Where do you get the whole lot? The above ones are only selling the one sprocket
Posted on: 2018/6/21 9:31
From WA perth
just the sprocket not the carrier that comes with it, is that plan enough
Posted on: 2018/6/22 8:34
I haven't seen any that sell only the rim (tooth wheel) of the sprocket, i've only seen them selling the rim + hub as a complete unit
If you already have an adjustable sprocket then the specific manufacturer parts only fit it. In other words a Tomei sprocket rim (probably) won't fit a Pitroad sprocket hub
Posted on: 2018/6/22 23:46
