FRONT SEAT SWAP
From Whangarei, New Zealand
Hi everyone! Currently in the process of changing out my low back seats in my 1200 sedan. I’d like to put high back bucket seats in (not full on race spec but something that has a fair amount of support in the sides.) If I do find seats suitable, I want to try and make the modification reversible so as I don’t butcher the originality of the car too much. Does anyone have any information or can lend me some ideas on this? Thanks guys
Posted on: 2018/7/8 8:16
Re: FRONT SEAT SWAP
what about WRX seats? fits in 1200
or
Posted on: 2018/7/9 10:34
Re: FRONT SEAT SWAP
From Mordialloc Victoria 3195
Honda late "90 Prelude/Integra are nice and narrow (well bolstered) Cheap at the wreckers
I fitted late "80 Celica seat in mine
Posted on: 2018/7/9 22:33
keep it simple
Re: FRONT SEAT SWAP
Is there a write up on the wrx seats? I happen to have a set from 2006. I might try and use them for my 1200 ute.
Posted on: 2018/7/10 0:07
Re: FRONT SEAT SWAP
Posted on: 2018/7/10 1:20
Edited by unfamilia on 2020/3/29 12:28:11
Re: FRONT SEAT SWAP
From Sydney NSW
Making aftermarket rails is not that hard but very time consuming. I have fitted aftermarket seats into my 1000. The biggest issue was finding a seat of appropriate width so it does not interfere with the door jamb and b pillar area.
Most seats will have a adjustable rail that is welded or bolted to the base of the seat, this needs to be removed and likely can be thrown away as it won't be even close to datsun size.
Measure the distances between seat bolt holes in the car and weld together some flat bar steel into a frame to bolt into the car as your new custom rail. Then the seat can be bolted to this custom rail.
I used this r31 guide as a bit of help the first time I had done it. I have done it in two different nissan/datsuns now with good success:
https://forum.r31skylineclub.com/index.php?topic=108649.0
Posted on: 2018/7/10 1:24
Re: FRONT SEAT SWAP
I have used a simple quick way with several different kinds of seats
* Unbolt the rails from the new seats
* Use the 1200 rails and the 1200 rail bolts (especially the small-round-head bolts). By using the original bolts, it's at least as safe as original 1200 design
* Use simple flat plate with four holes drilled (original holes + 1200 rail holes
For flat seat with totally flat runners, datsa74 used another method using the new seat's rails (also quick and simple)
Posted on: 2018/7/10 6:19
