B140 Bakkie: Girlock brake pad help needed
Quite a regular
From Christchurch, NZ
Hey folks,
Can anyone supply aftermarket brake pad part numbers for the Girlock single piston calipers on South African Bakkies please??
Cheers!
Posted on: 2018/10/23 11:14
Re: B140 Bakkie: Girlock brake pad help needed
From Perth
Never seen the caliper on SA cars
Usually they used ATE brakes on their vehicles
DO you have a pic ?
Posted on: 2018/10/23 12:52
Brake pad part numbers? 1988-2008 bakkie uses beefy Girlock calipers and large pads
Pad Type: D982/D949 104 x 61.0 x 15.50 mm, aftermarket pads include:
* ATE 524
* WVA 21170
* Brembo P 41.003
Fits:
* 1988-2008 Nissan 1400
* 1983-1987 Nissan EXA 1500
* 1983- Nissan Langley (locally assembled)
* 1983-1987 Nissan Pulsar 1300 S, 1500 GL
* 1997-1999 Nissan Sabre 160i GXi
* 1987-1992 Nissan Sentra (All Models except - 1.6 GXEi, 1.8i 16V)
* 1989-1992 Nissan Sentra 1.6, GXEi, 1.8i 16V
* 1997-2002 Nissan Sentra All Models except 200STi & 200GS
Posted on: 2018/10/24 4:11
From Perth
mint16
Lada Samara pad
GDB469 in Lucas brand
221 00 in Remsa brand
Or try DB1136 in Bendix (old # they have deleted them)
Posted on: 2018/10/24 13:36
Quite a regular
Hey ddgonzal, I tried these part numbers here in NZ with next to no success. Different markets, different luck I guess!
Posted on: 2018/10/28 19:09
Quite a regular
Cheers dattoman_1000, looking forward to seeing how I go with your info!
Posted on: 2018/10/28 19:10
Yea, that's South Africa parts
Beware, some of the D numbers come in different versions. This is what the bakkie Girlock pads look like compare to yours:
jpg  D989.jpg (46.22 KB)
174_5bd6d2c52efcb.jpg 800X600 px
jpg  nissan-1400-98-exa-83-87-langley-83-pulsar-sabre-sentra-front-brake-pads-d949.jpg (46.15 KB)
174_5bd6d2d0ed23c.jpg 600X600 px
Posted on: 2018/10/29 9:28
Dattoman, what year Bakkie is that for? Those Lucas etc. part numbers look very similar but are larger than the 1998-2008 bakkie pads
LADA/VW GOLF
119.5 x 74 mm
BAKKIE 1998-up
104 x 61 mm
Mint16, which pads do you have? 104 mm wide or 119mm wide?
Posted on: 2018/10/30 7:54
scratch that, I was looking at the wrong one
LUCAS GDB469/GDB 469
TRW LMS116
(Lucas was taken over by TRW Automotive in 1999)
LADA
* backing plate same width, but 1mm taller + pad goes down closer to hub
* Takes up 4.6 mm more in the caliper (each pad is 2.3 mm thicker). If the piston will compress that much it will fit in
Might do
jpg  TRW GDB 469.jpg (67.99 KB)
174_5bd81881116cc.jpg 400X400 px
Posted on: 2018/10/30 8:37
