Browsing this Thread:
1 Anonymous Users
Late 1200 intake manifold for water-heated carburetor |
Registered Users Contentmaster Usermaster
1989-up A12 manifold * Round-port * wet style intake, * new bolt-pattern * extended-length carb flange with water passage
Posted on: 2018/12/11 8:35
Re: Late 1200 intake manifold for water-heated carburetor |
more photos * with air cleaner bracket (side-bolt bracket) * hose for PCV valve (in same place as 1970 manifold) * Vacuum Connector forward hose goes to Vacuum Switch bolted to left strut tower
Posted on: 2018/12/12 3:13
Factory heat shield
and complete package * variable-mixture carburetor * air-temp controlled aire cleaner & brackets * cold air intake duct * hot air tube * fuel rail with return line
Posted on: 2018/12/14 1:38
wonder what the Vacuum Switch is for
Nissan 22360-01M00 / Hitachi SPDB28-115
used by Y10, N12/N13, B11/B12, W11 for "swirl control" but the 1200 doesn't have that
Posted on: 2018/12/14 4:32
