« 1 (2)
Re: Suspension problem
could be
when the wheel is off the ground on the jack you can lift it fairly easily on passenger side for first 1/2 inch
Check two things first
* Strut shaft nut -- is it loose?
* Anti-swaybar links, are they attached?
jpg  12526_53f7d901e3a1f _.jpg (140.07 KB)
174_5c195e2609b4a.jpg 1024X768 px
Posted on: 2018/12/18 20:52
From Tamworth, NSW
Thank you,
I will check. I did replace the sway bar rubbers so maybe i missed something.
Posted on: 2018/12/18 22:01
Project coupe:
Just drive it
« 1 (2)
