WTB Early A series alternator brackets or right to left side Alt conversion plate
From Sydney, NSW
Hi All just looking for early a series alternator brackets and bolts to move my alternator to the passenger side of a late model engine using the standard AC mounts
so Open in new window
and if someone does these as a kit I'd love that blank plate: Open in new window
Thanks!
Tom
Posted on: 2019/1/17 23:36
Re: WTB Early A series alternator brackets or right to left side Alt conversion plate
If you take a flat piece of aluminum 5mm (or steel 3-5mm) and drill the holes
* need early Adjuster bracket (shown in photo)
* use late alternator bracket from your existing engine
The dimensions are same as the bolt bosses on your A14/A15/lateA12 engine block, so measure yours to be sure, or make a mockup out of paper first. I put some measurements on the photo but its just a guess based on my notes of the block dimensions
jpg  are these correct.jpg (46.09 KB)
174_5c417ea52f468.jpg 512X288 px
jpg  late alternator bracket.jpg (27.68 KB)
174_5c4180dd8d3e6.jpg 500X244 px
Posted on: 2019/1/18 7:32
