WTB: fan shroud for stock 120y radiator
Looking for a fan shroud to suit stock 120y radiator. Car is running a little hot for my liking and starts to overheat in traffic :/
Posted on: 2019/6/8 8:45
Re: WTB: fan shroud for stock 120y radiator
In my experience, the fan shroud did nothing to solve the problem. Only replacing the radiator with one in like new shape, or a slightly bigger one, did
B110 330 x 344 x 32 mm
B210 330 x 344 x 32 mm
B210 330 x 462 x 33 mm with AC
B310 330 x 462 x 33 mm std (non-AC)
Nowadays the least expensive option is a cheap alumumum radiator -- brass & copper is very expensive. Some of the aluminum ones have a denser core, or thicker core, so they will cool better than the brass/copper
Posted on: 2019/6/8 8:58
It's a new build, new water pump and new Gemini radiator. The radiator seems narrow and there's a large gap between the fan and radiator. Those aluminum raditors look a lot wider.
Posted on: 2019/6/8 11:34
Then a shroud would probably help due to the gap
Another thing that might help a 1200 is blocking off the gaps between radiator and body
jpg  P8290554.jpg (117.21 KB)
174_5cfc05a673eda.jpg 1024X768 px
Posted on: 2019/6/8 19:59
