75/50W SEALED BEAM HEADLIGHTS
Quite a regular
From Ballarat Vic
Hey guys can anyone tell me if i can use 75/50w sealed beam headlights in my 77 120y without upgrading the wiring
Posted on: 2019/6/18 9:59
Re: 75/50W SEALED BEAM HEADLIGHTS
50/40W original specification
The good news is that the headlight wires are heavy-duty 12 gauge (at least in the B110). This means they can handle the 75W bulbs. So no need to replace the headlight sockets and wires. However the main fusible link is only 20 gauge...
just add a relay to bypass the main harness and feed in power through an extra Fuse
Battery --> 20A fuse --> 20A relay --> to existing headlight socket (cut wire and splice in)
Use an inexpensive 20A relay from an old Nissan. Or buy a new inexpensive 20A relay. See Headlight Relay
Posted on: 2019/6/18 10:39
From Tamworth, NSW
I just did this upgrade for our Plymouth Duster.
Its just plug in!
Wiring Harness
Cheapest and easiest way to upgrade your lighting circuit. Now no high current needed through the light switch!
Posted on: 2019/6/21 0:34
Project coupe:
Just drive it
Wow, that's the way to go, even used parts will run more $ than that
Looks like it has a fuse on the red wires. Do you connect that straight to the battery cable?
jpg  plug-n-play relay harness.jpg (29.79 KB)
174_5d0c702f1311a.jpg 586X588 px
jpg  signal plug + new headlight plugs.jpg (21.20 KB)
174_5d0c703866b04.jpg 585X586 px
jpg  new earth wires.jpg (20.96 KB)
174_5d0c703fe2d4f.jpg 585X587 px
Posted on: 2019/6/21 6:50
From Tamworth, NSW
Yes its a fused wire. Done in minutes. The only concern i had is with the quality of the relays, but i guess i will just replace them if they ever blow.
Posted on: 2019/6/24 0:23
Project coupe:
Just drive it
So can this be used to upgrade from sealed beam headlights to H4 halogen?
Posted on: 2019/6/24 7:49
H4 halogens will plug into the orginal wiring. However the original wiring is not rated for the extra current flow. That eBay kit specifically says it works with H4 bulbs (100W/90W type). It will also work with 75W Halogen bulbs or even with stock-specification bulbs (50W/40W)
Posted on: 2019/6/24 8:10
I might have to give it a go then. I have had a set of Hella halogen inserts kicking around in the garage for years....just have to find them now!
Posted on: 2019/6/24 8:57
Quite a regular
From Ballarat Vic
That harness looks easy enough and cheap so might be the go i think cheers
Posted on: 2019/6/24 9:32
From Tamworth, NSW
They should be an upgrade even if you use the standard bulbs as there will be more current available to the globes compared to the standard wiring harness.
Posted on: 2019/6/25 1:31
Project coupe:
Just drive it
