Electric fuel pump
From Mt Warrigal NSW Australia
Can anyone suggest a suitable electric fuel pump for an A12 with a weber 32/36 DAGV and stage 2 cam?
Posted on: 2019/8/8 1:51
Re: Electric fuel pump
From Hawaii, USA
If you can find an old Facet pump they work well
* Weber wants 2.5 to 3.0 lbs pressure, most pumps are higher pressure, for example A14 pumps are 3.2 lbs. Stock A12 fuel pump is 2.8 lbs.
* Weber recommends 6/gallon per hour, which is about what the stock A12 pump does. It is sufficient for 150hp
Posted on: 2019/8/8 4:31
From Hawaii, USA
Most electric fuel pumps nowadays start at 4 psi (too much pressure)
Look for fuel pump for carburetor
bing search for example Edelbrock 17330 3-psi electric fuel pump $28.44 closeout price
High-flow suitable for V8 engine -- or for a little 1.2 liter engine. Low enough pressure for a Weber 32/36
You could also buy a 4-7 psi pump and add a fuel pressure regulator
Posted on: 2019/8/8 20:48
Thanks for the prompt reply. If the stock A12 mechanical fuel pump is sufficient I'll stick with that. I thought the weber may need more fuel.
Regards, John
Posted on: 2019/8/12 2:09
From Hawaii, USA
sounds good. Just test the pump to ensure it still meets the specs (volume test & pressure test). Fuel pump pressure test
Posted on: 2019/8/12 4:21
