Gx 0.6mm headgasket
From melbourne
Hi guys im looking at the headgasket in the link below its a GX gasket 0.6mm, reason for needing it is to decrease piston to head clearence (increase quench) and increase compression abit along with the fly cut flat tops.
My question is that on the wiki it says its to suit a 79mm bore engine but on the Website it says will suit all a12 a14 and a15 engines.
So will it be find for a a12 with standard bore size of 73mm?
https://www.ebay.com/itm/GENUINE-DATSU ... c1123e:g:KJ8AAOSwwmlZgxsD
Thanks!
Posted on: 2019/11/28 6:30
Re: Gx 0.6mm headgasket
Yes, 79mm bore gasket fits all 76mm A14/A15 and all 73mm A12
Posted on: 2019/11/29 2:37
That link is for the factory GX/A12T gasket. I don't know if it fits an A14 as (per Datsun) it is for A12 engines
The Datsun gasket 79mm bore is 11044-M0822
Reasonable price
A1044-H232E [11044-H2325]
jpg  A1044-H232E.jpg (72.57 KB)
174_5de7814f66f37.jpg 1000X424 px
Posted on: 2019/12/4 9:52
Here is the Nismo 79mm 0.6mm gasket which is fine for an A12
Bprojects
About $40 USD + shipping
Factory A12 gaskets are 74.5mm so they will tightly fit oversize pistons. If you fit a 79mm gasket it will still work and seal well. Theoretically the 74.5 is better for an A12 however it doesn't really matter, they use the 79 on racing A12
Posted on: 2019/12/4 9:58
From melbourne
Ordered the gasket sounds like it should work fine.
The factory pistons sit 0.35mm down the bore so il be looking at 0.95mm with the fasket which i think is still to much but should be better quench than factory.
Posted on: 2019/12/6 6:22
