« 1 ... 8 9 10 (11)
Re: DIY GILMER Drive A-Series
Datsun A-series long water pump gilmer pulleys $65ea.
I can produce an adaptor to mount this onto short nose water pump,
call 0416080462 for details
jpg  datwp.jpg (12.26 KB)
15999_55fa51e2c2f95.jpg 700X703 px
Posted on: 2015/9/17 6:39
I'm thinking of producing some more Gilmer drive kits Around the $200 mark, anyone want one?.
Also can make adaptor plates/brackets for AMR500/EATON R410 Superchargers.
Adelaide
Ph/txt 0416080462
Posted on: 2020/7/1 3:59
From Perth
I'm interested in a pulley
But it's a weird one
I want a V belt and a ribbed belt... and I see you do these
But I also want to add a crank angle sensor wheel to the back of it
Can this be done with the existing ones you do ?
And I want a spigot on the front to accept a toothed gear for running the dry sump pump.
So something like this crank wheel
And this spigot drive and spigot
Not specifically these units... just examples off the net
The pulley I would want a bit of weight in it like a proper harmonic damper
https://rossperformanceparts.com/produ ... -vk56-crank-trigger-disc/
https://rossperformanceparts.com/produ ... ptor-with-19t-htd-pulley/
Posted on: 2020/7/8 12:23
« 1 ... 8 9 10 (11)
