Browsing this Thread:
1 Anonymous Users
turbo camshaft Duration and valve lift lobe center? |
From Puerto Rico
Hello everyone, what kind of camshaft Spec. can I use in a Turbo A15 or A14 engine? It's my first time ordering a turbo camshaft is stock bore at: 9.0:1(135psi) compression Ratio Fuel injection reprograming ECU system turbo is 50/48mm. Thaks you for you Help
Regards, Dariel
Posted on: 2021/8/6 0:38
Edited by donditaa on 2021/8/6 1:28:41 Edited by donditaa on 2021/8/6 2:29:11
Re: turbo camshaft Duration and valve lift lobe center? |
Registered Users Contentmaster Usermaster
There are two kinds of "turbo" grinds: old school and modern. Old school makes 150HP from an A15, while modern can make 225HP
If you telephone a cam grinder you can get the latest information. For example fax Iskenderian at 310-515-5730
For old school, the Camtech A15 Turbo grind was 246/239 degrees advertised and 113 lobe separation
Posted on: 2021/8/8 1:18
