install E16 88mm Stroke Crankshaft to Datsun A15 Block?
From Puerto Rico
Hello, I am interested in increasing the stroke of Datsun to A15 using Nissan E16 counterweight Crankshaft. Has someone done that job?, or if any person have those Crankshaft fixed that fit on the A15 Block for sale. Thanks for Your Help
Posted on: 2021/8/9 1:13
Re: install E16 88mm Stroke Crankshaft to Datsun A15 Block?
we know of a few conversions: two Australia, two Finland, one Venezuela. There are likely more done by racers who are very secretive of the details
E16 crank stroke 88mm
In A15 block yields 1587cc with stock diameter pistons
Main Forum: whats involved in fitting an e16 crank or other e series cranks in to an a series
Lemonhead: Quote:
photo's of the E16 crank I have modified for the A-series block ...
[option I chose was to] modify the rear of the crank to make it similar to an A-series crank ... it's alot of work to do it right!
120ZZZ said: Quote:
I have 2 e16 cranks,what is fitted to a-engine.Thous cranks was meid over 10 years ago to turboengine.That modifigeisen was very expensive,but that crank is very strong in turbouseing.The best time in 1/4mile was 11.78/181km:h. ps.Mazda e5(1.5l and bore 77mm) and b6(1.6 and bore 78mm) pistons and connecting rods is good and easy fit,whit that crank.I gone use opel 1.6 ecoteck pistons(79mm) and mazda connecting rods to my non-turbo engine.
Google search: E16 crankshaft fit A15 block
E16 crankshaft modified to fit in A15 block
Posted on: 2021/8/10 0:31
I also believe the 88mm GA16de crankshaft can be made to fit with modifications.
Posted on: 2021/8/10 21:35
