What would be the compression ratio of an a12 with a10 pistons and h75 head?
From Adelaide, Australia
Hey all, just wondering what the compression ratio would be of an a12 with a10 flat top pistons and a stock h75 head? Trying to get around the 9.5-10:1 compression ratio. Would there be any valve clearance issues? Thanks
Posted on: 2022/1/9 13:35
Re: What would be the compression ratio of an a12 with a10 pistons and h75 head?
To achieve 10:1 - the stock A12 GX compression ratio - three things are necessary:
1. Flat-top pistons
2. extra-thin head gasket 0.8mm (Nissan 11044-H2301 GX gasket)
3. Combustion chambers of 29.1cc size (GX)
H89 can be blueprinted/skimmed to 29cc
H75: there are two H75 casting heads. One that is machined with open chamber (31cc). With standard 1.6mm head gasket will result in 8.8:1 compression ratio
With open chambers there is more run-on and detonation - even at lower compression ratios (ie. 8:5:1). More so at high CR. Reduce the spark timing to compensate. H89 head will not need this as it is closed chamber
jpg  11044-H2301 (with O-ring) Top.jpg (51.45 KB)
174_61db6370bcb85.jpg 1138X648 px
jpg  11044-H2301 Bottom.jpg (52.37 KB)
174_61db6436611e3.jpg 1138X648 px
jpg  11044-H2301 Head Gasket.jpg (29.51 KB)
174_61db643f50e30.jpg 600X450 px
Posted on: 2022/1/9 22:40
Thankyou again :)
Posted on: 2022/1/11 17:02
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
