« 1 (2)
Re: PB110 fog lamps
the bracket loops on the 1200 sedan grille
the bracket "loops" on the 1400 grille are not in the same place
jpg  pbg_.jpg (14.95 KB)
174_61de88ea649cb.jpg 592X160 px
jpg  pbg.jpg (15.45 KB)
174_61de88f81f378.jpg 592X160 px
jpg  pbg-.jpg (45.76 KB)
174_61de890226af7.jpg 600X450 px
Posted on: 2022/1/12 8:03
Re: PB110 fog lamps & grille
Here are some detail photos of the fog lamps. Actually all the pics of the same grille, why not
this grille has foglamps, but all the fog lamp brackets are missing. Even the lower metal piece along the bottom of the grille is missing
the bulb inside the lens appears to be amber
jpg  PBG4R_.jpg (63.85 KB)
174_61deabd0cab5c.jpg 976X576 px
jpg  PBG3R.jpg (74.28 KB)
174_61deabe0ddbe2.jpg 1089X471 px
jpg  PBG1.jpg (61.01 KB)
174_61deabec246c7.jpg 1137X363 px
jpg  backside without brackets PBG1_.jpg (64.59 KB)
174_61deac212bfa7.jpg 1144X388 px
jpg  V-shaped with protruding pods for fog lamps PBG2.jpg (64.21 KB)
174_61deac4ddbf43.jpg 1159X381 px
jpg  'S' Ornament PBG7.jpg (149.66 KB)
174_61deac6142702.jpg 960X1168 px
jpg  two bullet connector wires PBG1_.+jpg.jpg (18.76 KB)
174_61deac6b468ba.jpg 500X376 px
Posted on: 2022/1/12 10:24
1600 foglamps (GB211)
unlike the B110, foglamps for B210 bolt into the grille
B210 facelift variant B211 was produced 1976-1977 in Japan. The Sunny 1600 was the L16 engine-powered version
* triangular brackets with top bolt offset
* sloping lens with 'NISSAN' in center
* 30W bulb
Type H79 for the 1600
png  C-402_G26-03 フォグ ランプ.png (59.68 KB)
174_61e0fb0a8f373.png 1100X484 px
jpg  26150-H7926 LAMP KIT-FOG for OKINAWA.jpg (137.71 KB)
174_61e0fb1fc1284.jpg 1200X900 px
jpg  26254-H7900 RH bracket.jpg (108.86 KB)
174_61e0fb2e7018b.jpg 1200X900 px
jpg  amber lens 'NISSAN'.jpg (146.02 KB)
174_61e0fb419ee66.jpg 1200X900 px
jpg  Top screw for adjustment.jpg (139.16 KB)
174_61e0fb4e29fb0.jpg 1200X900 px
png  C-402_G26-03a Fog Lamp.png (119.65 KB)
174_61e0fb57cbb1f.png 960X442 px
png  KIT & SWITCH.png (186.48 KB)
174_61e0fcd032ab7.png 960X714 px
Posted on: 2022/1/14 4:26
Re: 1600 foglamps (GB211)
here's a 1600 grille up for auction that shows how the foglamps bolt on
jpg  1600 grille.jpg (43.09 KB)
174_61e1083a2963f.jpg 1120X320 px
jpg  grille backside.jpg (44.42 KB)
174_61e1084f66199.jpg 1120X320 px
jpg  LH.jpg (98.24 KB)
174_61e108938cc00.jpg 1152X704 px
jpg  RH.jpg (92.60 KB)
174_61e108a4cc829.jpg 1152X704 px
jpg  LH bracket.jpg (85.36 KB)
174_61e108db92558.jpg 1120X640 px
jpg  RH bracket.jpg (85.79 KB)
174_61e108e9c2283.jpg 1120X640 px
jpg  grille 'S' ornament.jpg (104.83 KB)
174_61e108fb808ea.jpg 1200X800 px
jpg  26254-H7900 RH - 激安魔王 auctions.jpg (50.73 KB)
174_61e10912bbdbd.jpg 600X450 px
Posted on: 2022/1/14 5:24
any ideas what is different for Okinawa? They have a different lens, but what is that about
H58 lens: 1600 Okinawa
H74 lens: 1600 Japan except Okinawa
H58 lens was also used by all the earlier 1400s, Okinawa or not
Posted on: 2022/1/14 7:04
1400 foglamps (PB210)
guess i should explain the 1400
Datsun Sunny Excellent 1400 was the Japan-only model with L-series engine
these Type 58 foglights bolt to the grille
png  PB210 C-261_220-1 FOG LAMP.png (131.00 KB)
174_61e519b595500.png 1309X867 px
Posted on: 2022/1/17 7:24
Edited by ddgonzal on 2022/1/17 7:45:00
Re: 1400 foglamps (PB210)
The PB210 used the same lens for all of Japan. PB210 was manufactured 1973-1975
26151-H5800 LENS-fog lamp RH
26156-H5800 LENS-fog lamp LH
The lens is clear but when installed it looks yellow/amber probably because the lamp reflector (housing inside) is gold colored
jpg  26151-H5800-.jpg (33.18 KB)
174_61e51f6aaa29d.jpg 720X464 px
jpg  26151-H5800 LENS-fog lamp RH.jpg (31.63 KB)
174_61e51f75aabaf.jpg 720X464 px
jpg  gold appearance.jpg (171.54 KB)
174_61e527a74c026.jpg 1152X992 px
jpg  p2 grille.jpg (23.16 KB)
174_61e5281b3f33d.jpg 576X160 px
Posted on: 2022/1/17 8:24
Because the grille is v-shaped, the lenses are sloped to match. Likewise the grill tucks in towards the bottom so the lenses are sloped in that direction as well
jpg  Slope - horizontal.jpg (117.44 KB)
174_61e5bd6835d56.jpg 1200X900 px
jpg  p2.jpg (71.65 KB)
174_61e5bd73aba85.jpg 576X720 px
jpg  Slope - vertical .jpg (82.23 KB)
174_61e5bd814ee52.jpg 900X1200 px
jpg  2a463f1b27ec99415dd7a7d052a26e9a.jpg (125.93 KB)
174_61e5bd8c1d5ef.jpg 1000X667 px
jpg  IKI JAPAN.jpg (135.58 KB)
174_61e5bf2d53069.jpg 1200X900 px
Posted on: 2022/1/17 19:12
They have the Sunny 'S' emblem on the lenses
also, note the method of alignment, so the beam can be aimed up/down
jpg  top adjustment screw.jpg (124.27 KB)
174_61e5c08f245b1.jpg 1200X900 px
jpg  bottom adjustment-pivot spring.jpg (77.70 KB)
174_61e5c098d2de8.jpg 1200X900 px
jpg  PB210 fog light - triangle-top bracket.jpg (95.11 KB)
174_61e5c0abb45a3.jpg 1200X900 px
jpg  backside.jpg (47.38 KB)
174_61e5c0b4f2490.jpg 716X832 px
jpg  wires with bullet connectors.jpg (83.69 KB)
174_61e5c0c5e759b.jpg 1200X900 px
Posted on: 2022/1/17 19:17
« 1 (2)
