B210 Grille
Whether you have a 120Y or a B-210 they are all Datsun Model B210, the 2nd generation of the Sunny line
Early Sedan (1973-1975) shark gille type
Early Coupe honeycomb type
Late Sedan (1976-1978) B211-type
Late Coupe
Excellent 1400/140Y/160Y
Excellent 1600
jpg  64926_505551436151274_2060827923_n.jpg (23.16 KB)
174_61f0ea1e1105b.jpg 640X128 px
jpg  B211-grille-1.jpg (18.62 KB)
174_61f0eb318f2d5.jpg 576X144 px
jpg  1865.jpg (36.08 KB)
174_61f0ed1c6b1ff.jpg 1184X288 px
Posted on: 2022/1/26 6:45
Coupe Grille - early B210
KB210
classic honeycomb mesh style grille
The round holes were fitted with fog lamp blanks on 1200s (120Y and base level B210s)
For Lamps were an OPTION
North America had the Turn Signal indicator lamps in the grille (because they wouldn't fit in the front bumper)
Posted on: 2022/1/26 7:26
Re: Coupe Grille - early B210
6 bolt holes along top edge
6 bolt holes along bottom edge
jpg  Fog Lamps 11320_4a64275c3fdc9.jpg (25.98 KB)
174_61f0fb6f826e6.jpg 800X244 px
jpg  KB210_sunny_471_1.jpg (113.04 KB)
174_61f0fb7d0dff0.jpg 1280X960 px
Posted on: 2022/1/26 8:25
grille is exactly the same USA or JDM
62302-H5500 JDM GRILLE KIT-radiator K-DX,K-GL
62302-H5500 USA GRILLE KIT-radiator Coupe & Sedan
the difference is the fittings:
* 'D' badge instead of 'S' badge
* T/S indicator lamps instead of blanking plates (masks) #5 in diagram
* Fog Lamps on GX (Japan Market) #8 in diagram
jpg  C-260_400 RADIATOR GRILLE.jpg (91.36 KB)
174_61f109c71ce13.jpg 1200X786 px
Posted on: 2022/1/26 8:44
eBay photos of the grille with the North America T/S indicator lamps installed
for USA/Canadian cars they all used this grille 1974-1975. Yes, sedan used the coupe grille
jpg  K0 3-D sculpted look.jpg (58.22 KB)
174_61f10d502a2b7.jpg 1280X320 px
jpg  K1 broken bottom tabs.jpg (32.39 KB)
174_61f10d68dfca2.jpg 1200X272 px
jpg  K2.jpg (60.43 KB)
174_61f10d7c09744.jpg 1152X512 px
jpg  K3.jpg (75.98 KB)
174_61f10d8ad1a98.jpg 1200X560 px
jpg  K4 grille back side (upside down).jpg (99.86 KB)
174_61f10da0a2dc5.jpg 1200X656 px
jpg  K5.jpg (56.88 KB)
174_61f10dac80fba.jpg 1200X416 px
jpg  K6.jpg (39.16 KB)
174_61f10dcc81314.jpg 1200X304 px
Posted on: 2022/1/26 9:02
Re: Coupe Grille - early B210 - mounting points
the grille has 6 bolts top and 6 bolt bottom + 3 pins maybe to center the grille while it is screwed down. The pins fit into rubber pads, much like modern cars
top edge of grille bolts to the core support
bottom edge bolts is the six yellow stars - need some photos of where it fits in the car
jpg  Top edge bolt points.jpg (74.36 KB)
174_61f1137860d31.jpg 1024X368 px
jpg  Mount points (upside down).jpg (107.27 KB)
174_61f11386b7ed7.jpg 1200X656 px
Posted on: 2022/1/26 9:25
