« 1 2 (3)
Re: A10 turbo. Has anyone done it? What are the limitations?
From Adelaide, Australia
The head I have atm is the m30 a12 head. Would it be worth any effort to go a h75 or h89 if one pops up? Do u think supercharging would be a better street option then turbocharging? Also, a long time ago there was a very simple 1 injector setup for the a series, any idea where that info is? I recall there being a simple a12 injection setup maybe using daewoo or Hyundai parts. Was a long time ago
Posted on: 2/21 2:09
Posted on: 2/21 2:42
Just another thing. Say if my Max rpm was around 6500rpm. Do the stick m30 valve springs do around that. I think they are rated around 6000rpm but from memory, I think I might have been able to take my old stock a12 to around 6400rpm. Is this correct or should I look at double valve springs?
Posted on: 2/21 6:03
From Perth
I have this ugliness for a round port in the shed
Home made by someone
I bought it from a guy rather than him scrapping it... to this day not sure why
Maybe for this moment
jpg  20220221_180407[41168].jpg (177.40 KB)
527_621366fdc973b.jpg 1200X900 px
jpg  20220221_180652[41166].jpg (188.19 KB)
527_6213676f5636b.jpg 1200X900 px
jpg  20220221_180706[41165].jpg (177.21 KB)
527_6213678067e61.jpg 1200X900 px
jpg  20220221_180701[41164].jpg (182.63 KB)
527_621367e01c673.jpg 825X1100 px
jpg  20220221_180744[41163].jpg (179.61 KB)
527_621367e96ca5e.jpg 1100X825 px
jpg  20220221_180400[41171].jpg (181.68 KB)
527_621368cfa39a4.jpg 900X1102 px
jpg  20220221_180645[41172].jpg (188.81 KB)
527_62136997ecf4c.jpg 713X1000 px
Posted on: 2/21 10:22
Re: valve springs
From Hawaii, USA
A12s have a red line of 6400 rpm, meaning the stock valve springs are designed to reliably rev that high
Double valve springs create more friction, thus higher wear, lower fuel economy and less power. To make more power at higher RPMs, it needs more camshaft, large port head, and stiffer valve spring. And a willingness to rev it up and shift every few seconds
Posted on: 2/21 19:03
From Hawaii, USA
that's awesome
* The log plenum looks like a Mazda unit modded for an A-series
* The exhaust manifold looks rough, but how it works is more important
* The intercooler is great for a 1-litre engine and can be mounted wherever
I'd use it. Use a single Hitachi or SU carburetor and it's good to go. If you want to do EFI it's a lot more work, and needs more tuning, see $1200 EFI Turbo A12
Posted on: 2/21 19:27
Ddgonzal I think u may have answered this in a previous post. So what sort of engine hp would I be looking at with an a10 bottom end, m30 head (which is the only head I have), around 15psi with a simple injection setup (fuel and ignition)?
Posted on: 2/22 0:25
From Hawaii, USA
80kw with simple EFI (single injector/central fuel injection) and ECU-controlled spark
Posted on: 2/28 20:25
I am going this route. I am looking at the Hyundai Accent throttle body.
The adaptor I am looking at importing from the UK.
If I can find a complete MP9 VW kit I would go that route with some modification to the runners.
Posted on: 3/2 11:07
« 1 2 (3)
