What could BEE 310 Project
Hi Everyone,
I am from Perth, Australia and bought this one on a bit of a whim in Jan this year. Certainly, wasn't looking for a sunny (Formally owned 510's) however the condition, price and a brief moment of weakness made it happen.
One owner from new. Full history, 60,000km on original A12. Next to no rust, mint interior and body.
Was planning on keeping it fairly original apart from rims and an SR20 transplant however after doing some research and all the upgrades required (brakes, diff etc) I realise I don't have the time and money to drop into it with small kids running around.
Instead, I'm planning on going down the Turbo A12 route after reading Sykine's inspiration budget build thread. I thought I'd give it a go.
I'll post the progress here and hopefully get a hand as well if I can.
Cheers.
jpg  IMG_9709b.jpg (51.34 KB)
5053_634de608de738.jpg 591X443 px
Posted on: 2022/10/18 8:53
Re: What could BEE 310 Project
Online
hey that's nice
Is it a 1980 GL?
Posted on: 2022/10/18 12:15
Thanks, yeah its an 80' Model but not sure if its a GL or not. How would i tell. It has no fancy tacho or nice bumpers so i'm assuming its the povo pack.
Posted on: 2022/10/19 0:24
Online
Not sure about your country, but in Japan the GL trim had the bumper with rubber-covered ends. In Europe it seems this was standard on all trims
The style wheels with beauty rings were an option, but I think they were 13"
The lowest trim B310 had 12" wheels. All the A14/A15 models came with 13" wheels
The lowest dash had a blank plate next to the speedometer, but GLs had gauges there. Here are some JAPAN-market and USA-market photos
jpg  Sedan (2 large gauge + 2 small gauge with Digital Clock).jpg (51.95 KB)
174_634fbbfd383dd.jpg 1024X628 px
jpg  1982-210-dash (2+2 with blanking plate).jpg (92.24 KB)
174_634fbc1c24f96.jpg 1200X900 px
jpg  1 (2+2 with digital clock).jpg (40.00 KB)
174_634fbc2a44644.jpg 960X539 px
jpg  WHB310m1 (2+2 with Analog Clock).jpg (37.67 KB)
174_634fbc3eee7c2.jpg 960X480 px
jpg  WHB310m2.jpg (38.33 KB)
174_634fbc4962747.jpg 960X480 px
jpg  WHB310m3.jpg (54.28 KB)
174_634fbc5a2bceb.jpg 800X600 px
Posted on: 2022/10/19 9:32
Edited by ddgonzal on 2022/10/19 9:59:11
Well turns out it is a GL based on the badge on the boot lid I forgot about.
A few more pics as well (painful that the photos have to be so small)
jpg  thumbnail_IMG_8613.jpg (73.60 KB)
5053_6350b82a897a2.jpg 640X480 px
jpg  thumbnail_IMG_8620.jpg (66.10 KB)
5053_6350b834e3696.jpg 640X480 px
jpg  thumbnail_IMG_8624.jpg (87.38 KB)
5053_6350b84220e99.jpg 640X480 px
jpg  thumbnail_IMG_8629.jpg (104.23 KB)
5053_6350b84ce555e.jpg 640X481 px
jpg  thumbnail_IMG_8701.jpg (52.46 KB)
5053_6350b8545480c.jpg 640X480 px
Posted on: 2022/10/20 3:54
Online
hey that is nice inside and out. With the price of petrol, enjoy its 35 mpg efficiency!
re: the pics, they are small but still big enough to get the idea across. Thanks for posting them
Looks like it has the factory optional digital clock, I think 1980 was the first year they were available
Posted on: 2022/10/20 11:50
I have been tossing and turning on this and have recommitted to the SR20det engine swap.
I have been reading about the Stanza/(A10) cross member that bolts into the B310 has the mounting position that will suit the SR20det engine brackets making it all a driect bolt in without any cutting or welding. Can anyone verify this?
Further, I can't find any info on whether the suspension from the B310 will bolt straight back up to the stanza/(A10) crossmember or you need suspension parts from the stanza/(A10) also such as control arms and tie rods etc.
Also, I can't seem to find anything about the gearbox crossmember options. I presume modifying the sr20 gearbox xmember to suit is the best bet?
Any help would be much appreciated.
Posted on: 2022/11/21 23:45
Online
Are you sure the A10 crossmember will fit the B310? B310 uses three different LCA, depending on year. Thankfully all use same ball joint & bushing. Perhaps they have just minor production updates and are interchangeable?
The suspension that bolts to the crossmember is:
* LCA
* Ball Joints (A10 uses the larger of the B310 units)
* Tension Rod
* Swaybar link
The SR20 from RWD cars uses the same mount location as L-series and CA-series, so that's why they say A10 crossmember (for L-series engine) will work with SR
Posted on: 2022/11/27 0:58
Hey ddgonzal thanks for the info. In the end I bought another 80' model B310 with a running CA18Det in it that I am going to remove and transplant into my B310 so thankfully all of the fitting kit questions have answered themselves.
I will keep you updated as things progress.
Posted on: 2023/2/14 7:32
