Browsing this Thread:
 1 Anonymous Users
       |  | Wheel bearing replacement 120y |  |
  	| Just popping in
 From South Africa  Group:
 | Hi it's been a while! I'm replacing front wheel bearings ('75 120y) and I have had to remove the knuckle in order to get the lower caliper bolt out! Is this right? All the service manuals i've found just say "remove brake caliper" but I can't get to bolt out!
	    Posted on: 2023/3/18 7:21 |
       |  | Re: Wheel bearing replacement 120y |  |
  	| Moderator   Joined:2001/5/3 7:04
 From Kent, WA  Group:
 | No need to remove the knuckle. Just need to loosen the bolts. Is it a 120Y Coupe or 120Y 4-door
 On the 1200, which uses the same strut as the Japan-built 120Y:
 * loosen both strut-to-knuckle bolts just slightly
 * on the side where the caliper bolt won't come out, completely remove the strut-to-knuckle bolt
 * rotate the strut a little bit. Now the caliper bolt can be removed
	    Posted on: 2023/3/21 10:20 |
  	| Just popping in
 | Thanks! I was worried that I was missing something or that i had used wrong parts when I rebuilt the front end many years ago!It is a 120y 4 door that has been in my family for 45 years!
 I followed your procedure with one addition. I had to remove the top caliper bolt and swing the caliper out slightly in order for the strut bolt to come out past the piston.
 Many thanks for the info.
	    Posted on: 2023/3/21 20:36 |
