56a series gearbox in a 1000. Do I use the 56a crossmember?
From Adelaide, Australia
Just double checking. Does the standard 56a gearbox crossmember fit to a 1000 body or do I need a 1000 gearbox crossmember? Thanks
Posted on: 2023/4/26 11:21
Re: 56a series gearbox in a 1000. Do I use the 56a crossmember?
The standard 4-speed gearbox is the 56. The newer gearbox from the B120 and B210 is the 56A 4-speed Both use the same mounting points
A different crossmember is used for the 5-speed 56
Posted on: 2023/4/26 17:42
Si I'm a little confused. With a 1200/120y gearbox, do I need the 1200/120y gearbox crossmember to fit in a 1000 or the 1000 crossmember? Thanks :)
Posted on: 2023/5/1 12:18
Use the 1000 crossmember
There are two "56a" gearboxes: the 56a four-speed and the 56a 5-speed. The 5speed uses a different crossmember. The older 56 4-speed uses the same crossmember as the newer 56a 4-speed
The answer is different if you fit a five-speed 56a
Posted on: 2023/5/3 7:53
