Need help to remove a pin dowel from selector shaft 56A box
Would anyone have any tips/tricks to remove the pin dowel (hope this is the correct term) form the selector shaft in the rear extension housing? Happy to pay someone in Melbourne if you have a special tool to minimise damage. Thanks
jpg  IMG_1566.jpg (55.25 KB)
12605_645cdbbfde8ba.jpg 320X240 px
jpg  IMG_1570.jpg (30.73 KB)
12605_645cdbc9e05ce.jpg 320X240 px
Posted on: 2023/5/11 13:13
Re: Need help to remove a pin dowel from selector shaft 56A box
Wow is that a 5-speed? It doesn't look like the usual 56A 4-speed
I believe you can use a punch to lightly tap the pin back out. Not much room in the extension housing though. Is it stuck tight?
The LOCK PIN fastens the STRIKING LEVER to the ROD
18 32896-H7200 LEVER-striking
19 32917-H7200 PIN-lock
20 08915-13610 WASHER-lock
21 08915-53610 WASHER-plain
22 08911-20610 NUT-hex
Posted on: 2023/5/14 21:22
Hi, thanks for the reply. Yes it’s a close ratio 5 speed, I tried tapping the pin with a hammer and got quite a good impact on it despite the lack of space, but it seems well stuck. I will try and clamp down on it with vice grips and apply heat on the weekend, and see what happens.
Posted on: 2023/5/17 13:42
