Browsing this Thread:
1 Anonymous Users
B210 clock |
Registered Users Contentmaster Usermaster
B210/120Y had four clocks
* Square, compact * Square, large * Round, compact * Round, large
Large 3-needle type and small 2-needle type. There are two types: square and round. The design is also stylish.
Posted on: 2024/2/14 20:21
B210 clock: compact square |
The compact clocks fit * to the far side of the radio * above the cigarette lighter
compact/small Square type (kaku)
Posted on: 2024/2/15 5:11
Re: B210 clock: compact square |
To fit the small clock, remove the dash, unscrew the blank plate, screw the clock in and connect the wires to the existing dash harness
Posted on: 2024/2/15 5:53
There's one for sale on Yahoo -- brand new for $280 https://page.auctions.yahoo.co.jp/jp/auction/t1122753785This one is 27380-H5010, for 1977 models (from June 1976). Looks like the early version H5001 and since the connector is so simple, i reckon it will work without modification in any B210 The clock has CITIZEN on it, but suprisingly the warranty card says "KANTO SEIKI". As far as I can tell, they were never the same company. Citizen Watch Co., Ltd.シチズン時計株式会社 関東精器株式会社 Kanto Seiki Co., Ltd.Kanto Seiki was a spinoff from Nissan since 1956, and made the speedometers and other Datsun meters. Now merged with Magnetti Marelli Quote: Warranty
Thank you for purchasing a genuine Nissan auto clock. Please keep this warranty card in a safe place so that it will not be lost. Thank you.
1. Warranty period: One year from the date of purchase or up to 20,000km of mileage.
2. Scope of Warranty We will repair the product free of charge if the failure is determined to be due to manufacturing liability under normal usage conditions and you bring this warranty card with you.
3. Dealer: Nissan Motor Co., Ltd. sells our products at Nissan dealerships nationwide, so in the unlikely event of a problem, please contact us for repair.
4. Warranty exclusions We cannot guarantee damage caused by handling errors or if a warranty card is not presented.
Kanto Seiki Co., Ltd. 2-chome 2, Higashi-Shinbashi, Minato-ku, Tokyo
Posted on: 2024/2/15 6:26
B210 clock: large Round type |
$300 new in box https://page.auctions.yahoo.co.jp/jp/auction/w1090991751Round type dash (maru) was fitted to: * all JDM Coupes * Sedan GX Large clock was in the GL and DX coupes next to the speedometer. The GX had a tacho there, so used a small round clock off to the side
Posted on: 2024/2/15 8:45
Re: B210 clock: large Round type |
27380-H5600 was the original large round clock in 1973
looks like the same 3-pin connector as the small clock
Posted on: 2024/2/15 8:53
for sale now $300 new inbox https://page.auctions.yahoo.co.jp/jp/auction/w1090991751This is H5610, the 10 meaning alternate source (second-source manufacturer). Identical in mounting and connecting as with H5600. It's not clear but it looks like it might say CITIZEN at the bottom of the dial The back testing stamp says K.S. 45, perhaps meaning Kanto Seiki. [edit: dunno what the 45 means. I thought it might be the year, but Showa 45 would be 1970, which doesn't fit] B210 cars were introduced May 1973 I was able to find some clocks that have both Kanto Seiki and Citizen spelled out on the face, so the two companies had some kind of business relationship
Posted on: 2024/2/15 9:17
Edited by ddgonzal on 2024/2/15 16:44:56
B210 clock: Large square |
finally, Sunny enters the modern age with a classy rectangular meter package Rectangle dash was in * nearly all Export B210s including 120Y/140Y/160Y * JDM Sedan DX and Sedan GL * JDM wagon/van * except 140Z/160Z and asia markets which had round gauge dash Large square clock was in the center gauge cluster, next to the speedometer, as in this photo:  If no meter was there, a blank plate was installed If equipped with tachometer, a small clock was fitted off to the side:  [edit: corrected the MASK photo]
Posted on: 2024/2/16 18:56
Edited by ddgonzal on 2024/2/17 20:21:35
Re: B210 clock: Large square |
OK, so the large clocks themselves:
* Citizen * JECO * Kanto Seiki
The Citizen clock only has one bottom screw, the others have two?
Posted on: 2024/2/17 21:26
As the photos show, these various clocks look the same and have the same connector. Only the mounting tabs differ -- from looking at the parts catalogs and the photos, it appears the earliest large clocks have 3 mounting holes. And these were used all the way until 1978. Then the later clocks, like the Citizen, have only 2 mounting holes. Yet it was also used in early cars. my conclusion: 2-screw clocks or 3-screw clocks will fit all B210 square dash
This late parts catalog diagram shows a two screw clock
C-402 Fig. G27-16 CLOCK S,DX, GL+V late B210.png (52.00 KB)
Posted on: 2024/2/21 20:45
