Do ka24's fit sunnys (b310)? Do any mods have to be done to the trans tunnel?
From Adelaide, Australia
Hi just looking at buying a sunny. I'm pretty sure the a10 stanza crossmembers fit which allow the ka24 to bolt in but was wondering if the stock sunny (b310) transmission tunnel can accommodate the ka24 gearbox? The sunny I'm looking at is a manual
Posted on: 2024/10/24 13:25
Re: Do ka24's fit sunnys (b310)? Do any mods have to be done to the trans tunnel?
Quite a regular
The I used a Stanza Crossmember in a B310 to fit an L-series years ago, the KA should fit using one.
The box will fit in the tunnel, just but you can not remove the top bolts from the engine to gearbox with it in the car, you have to remove engine and gearbox as a unit.
If I were to do it again I would modify the tunnel
Posted on: 2024/11/24 3:57
