HELP: brake problem
From Adelaide
ok i had my rear drums all in parts as i was going to install my locker, i was also swapping my steering wheel over and hit my foot on the brake for about 3 seconds as hard as i could thinking it was the clutch. after that i had tried to put my drums back on but they wouldent fit over the pads as the pads had pushed out abit.
now i cant even fit the drum over the pads even when i have tried moving the 2 pads up and down to fit into the drum???
has any1 had this problem also??
does any1 know how to fix it?
cheers for all ya help fells
Dwayne.
Posted on: 2004/7/9 1:42
classic not plastic
Re: HELP: brake problem
A couple of ideas:
1. Push the two halves together, with force and slow patience. Slowly the cylinder piston will be forced back into the cylinder.
2. Turn the adjusting screws all the way out, then the drum should slip back on.
Be sure to adjust the drums after the wheels are put back on. Tighten as far as you can go by hand, then back off 1/4 turn so that the wheel turns. Better tight (a little drag) than loose (no drag at all).
Posted on: 2004/7/9 7:25
