wanted 2" lowered springs for stanza strut ( gemini ?)
From Sydney.au
i will be using them on stanza struts, without any length mods on the struts. have been told 2" lowered gemmi ones will do. any info appreciated. i can only find new 1" lowered springs thru Repco. havnt had time to go wrecker searching :(
Posted on: 2004/8/8 8:35
Re: wanted 2" lowered springs for stanza strut ( gemini ?)
From Warwick, QLD
Have you tried King Springs??? They do a low and a super low series. Does any model gemini springs fit??? They have a better damper rate isn't it????
Damo
Posted on: 2004/8/8 11:45
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Sydney.au
havnt tried king springs although im sure theyre good but their price would be king size too. if i can pickup 2nd hand ones ill do it.
i can get 1" lowered gemi springs from repco for around $90 which is with discount. but then i'd need to get them compressed and more $$
not sure of which series of gemini springs.. im blindly assuming any gemini spring.
Posted on: 2004/8/8 12:46
From Sydney , NSW
evilsim,
to my knowledge all gemini springs are the same (both early and late model). However, did the earlier post say to use a standard rate shortened spring ? Aftermarket lowered may be a little stiffer and hence too stiff for a street car - only a thought. I hope my brother still has a supply of stock springs so I can try it out for myself I suppose it is just a matter of matching the free lengths and working from that point back to the ride height you want.
Cheers
Posted on: 2004/8/8 22:28
From Perth W.A
king springs are only about $110 for a pair and are great so not too expensive.
Posted on: 2004/8/9 3:10
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
From Sydney.au
ive since bought lowered stanza king springs and have cleaned up the strut/caliper. looks good soon to be inserted. 120Y castor rods needed some grinding to fit a bolt next to where it sits on the stanza lower control arm.
Posted on: 2005/3/28 15:25
