What bits do you need for a single 42mm sidedraught webber?
From Sydney
If i had the manifold and carby what else do i need to get it fit?
Posted on: 2004/8/19 1:52
Re: What bits do you need for a single 42mm sidedraught webber?
From Sydney.au
you might need the linkage kit for your weber. if so - get a linkage kit which matches your inlet manifold. apart from that just some spare fuel line hose might be needed.
the linkage kit is good as it has new rubber spacers for between manifold/weber and a few other bits which are required.
goodluck
Posted on: 2004/8/19 7:47
