a14 valve clearance
Not too shy to talk
From Adelaide
hey i have planned to do a full service this weekend but i dont know what the valve clearance should be on an a14 and what is the best way to set it as i have heard of several different ways
cheers curtis
Posted on: 2004/9/16 13:34
Re: a14 valve clearance
According to my Sunny [B310] owners manual, both the A12 & the A15 use a tappet setting of .35mm, or 14 thou. I guess that the A14 is the same.
When the engine is thoroughly hot, remove the plugs & rocker cover. Rotate the crankshaft untill the rockers on number 4 cylinder are "on the rock" That is, with the exhaust valve just closing, & the inlet just opening. Adjust number 1 cylinder. Vice versa also holds true.
The same thing applies with numbers 2 & 3 cylinders. Just rotate the crank in half turn increments & watch the valves. When the valves for nimber two cylinder are on the rock, then adjust number three.
The two end cylinders are linked, & the two center cylinders are linked. Do it this way & you need to turn the crank only two rotations & you will get it right every time.
Removing the plugs just makes it easy to turn.
Posted on: 2004/9/16 17:07
Love your Datsun.
Treat it well.
From Castro Valley,CA USA
I think if you get the #1 cylinder at top dead center you can adjust valves 1,2,3 and 5. With #4 cylinder at top dead center you can adjust 4,6,7 and 8.
Come to think of it, it takes two rotations to do it this way as well.
Oh well, what ever is easier for you.
Posted on: 2004/9/16 21:15
Not too shy to talk
From Adelaide
adjusted valve clearence and car rus alot better along with a tune up but still get a strange tick noise when car is cold at low revs should i be worried?
Posted on: 2004/9/19 13:32
