Broken!!!!!
From Sydney Australia
Just broke my front left caster rod on the SR1200 puttin it out of action till I can get a new one
There was a post recently about stanza parts, did you have any luck? Any help for stanza spares in syd?
Datto racers does this happen often or am i a freak that breaks everything?
Posted on: 2004/9/17 14:12
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
Re: Broken!!!!!
the rod broke?
I've heard of the bracket that holds it to the frame up front breaking, but not the rod.
Posted on: 2004/9/17 16:11
Re: Broken!!!!!
From Sydney, Australia
I've got a pair of '82 stanza Castor Rods you can have, I'm in Cronulla Sydney. I've got a pair of standard 1200 ones too if they are any use.
Let me know if you want them.
James
Posted on: 2004/9/17 22:31
Datsun nerd
Re: Broken!!!!!
I snapped it clean off possibly a fault when the the thred was tapped 30 years ago or so. Or maybe sydneys shocking pot hole filled roads are to blame.
Was just about to pull in the driveway and I heard this bang kind a noise and then shrapnel hittin the road, the left side dropped down bout an inch and a half.
Lucky it was just as i was gettin home!!!
Posted on: 2004/9/18 3:21
Re: Broken!!!!!
Sent you a PM jenson
Posted on: 2004/9/18 13:35
Re: Broken!!!!!
From T'ville
i have always thought of taping a thread on the rod just after the control arm on the thickest part , and then finding a rod size to go over it with bushes that suit !!!
or just use LC/LJ torana radius rods!!!!
Posted on: 2004/9/18 14:17
Re: Broken!!!!!
The Dato is back in action
Cheers Jempson for the rods, they didnt fit found out the rods on there were modified, more than 12cm of extra thred!
I just got the rod machined and tapped for very cheep at the gear makers at Kirrawee except the cost of the die nut I had to get cause the gear makers didnt have one the right size but I got it now for next time it happens!
Is there any way to measure the caster at home or should i just get it adjusted by a wheel alignment place?
I put the ajusting nuts approxamitly where they were on the old rod by measuring the distance between the seccond hole and the nut on each rod, I will test drive it soon should be pretty close.
Posted on: 2004/9/24 3:05
Re: Broken!!!!!
From Toowoomba QLD
Get someone to set it correctly, You maybe able to get it close but even a couple of mm out will make a big difference.
Posted on: 2004/9/24 3:10
Re: Broken!!!!!
From Toowoomba QLD
And the castor changes all other alignment settings.
Posted on: 2004/9/24 3:11
Re: Broken!!!!!
Cheers Datto7.
P.S. nice avtar
Posted on: 2004/9/25 2:28
