Browsing this Thread:
1 Anonymous Users
weber or SU turbo setup? |
Quite a regular
From Burlingame , CA (near SF)
I have a crazy idea but i was thinking of running a turbo with a single weber, but most of who are running a turbo are using SU's? is there a reason behind this? any way i just want to hearr what you think on me running an l18 with a sibgle weber turbo ne info will help thnx
Posted on: 2004/10/16 1:32
Re: weber or SU turbo setup? |
From Sydney Australia
Draw through or blow through?
SU for drawthrough for sure
Posted on: 2004/10/16 1:54
Quote: Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
Quite a regular
well i was thinkin of a blow through setup, but wat are the advantages to a suck through over a blow through?
Posted on: 2004/10/16 2:16
Registered Users Contentmaster Usermaster
Posted on: 2004/10/16 2:44
From SA the place to boost
su's are just as hard to tune with a turbo behind them, i personaly would be going the weber for sure!
Posted on: 2004/10/16 10:53
Quite a regular
just to set things straight i was thinking of a sidedraft weber with a turbo
Posted on: 2004/10/16 21:15
Quite a regular
I would also like to know the cfm ratings on the sidedraft webers of the 36 mm and the 44mm one? does anyone know what they are???
Posted on: 2004/10/17 4:51
Dunno about the specific CFM, but remember that two sidedrafts (not using a common plenum) does not double your CFM supply to the engine, more like 10%.
In other words, two SUs, each feed two cylinders, are not twice as good as a single SU feeding all four cylinders. But if they were feeding a large common plenum it would be twice the airflow.
Posted on: 2004/10/17 7:18
