diff to suit
Quite a regular
From Sydney,Campbelltown.NSW
hey i have a 200b with a z18 turbo, and i blew my diff the other day. the old diff was a stanza and now i am looking at a bigger one i have been told that a hilux diff would be good dose anyone know how hard it is to put them in and how much they would cost to do. also if anyone knows any cheap and easy convertions other than hilux let me know. thanks guys
Posted on: 2004/10/11 7:09
Re: diff to suit
See the Tech Section article What Diff and LSD?.
Posted on: 2004/10/11 7:23
Re: diff to suit
From SA the place to boost
hey dude the Series 3 bluebird H190 is ment to bolt strait into the 200B
Posted on: 2004/10/16 11:30
Stanza L20 Turbo
Bluebird Series 1 FJ20ET
Bluebird Series 3 TRX CA18DET
Re: diff to suit
DATTO_BOY wrote:
hey dude the Series 3 bluebird H190 is meant to bolt straight into the 200B
I have no idea where you got that info, but i don't think that it is right.
The H190 diff center will not bolt into the H165 rear axle housing, that is if your 200B is an early one with the Jap rear end. Most 200B's came with the Borg Warner rear axle.
The Bluebird [910] rear axle assembly is about 2 or 3 inches wider than the 200B, so even if you got it in, you will need to address the wheel & tyre clearance problem.
I discovered the width diference when i was converting my early 200B rear axle [H165] to disc brakes [from a 910] I had both rear axle assemblies together while sorting out which parts to use,... & discard.
Datto_Boy
Perhaps you could let us know where you got this information. Have you done such a conversion yourself?
Posted on: 2004/10/16 14:43
Love your Datsun.
Treat it well.
Re: diff to suit
i got the info from OZDAT no i havent done it myself.
now in his first post he is talking about a hilux diff, last time i checked the CENTERS dont FIT FROM THEM EITHER.
dude log onto ozdat.com and PM nitros13 and ask him about it.
as far as i know it WAS a BOLT IN diff!
for those that dont belive me read this
http://www.ozdat.com/forum/viewtopic.php?t=903&highlight=200b+h190
Posted on: 2004/10/17 5:00
Stanza L20 Turbo
