LSD diff's
From Timaru,New Zealand
does anyone know if there is an LSD diff that will fit into a C20 housing at all?
Posted on: 2004/11/22 22:56
Re: LSD diff's
Depends on what kind of C20 housing it is (C20 is early Vanette, right)?
If it has a H165 housing, see What Diff and LSD?.
Posted on: 2004/11/23 2:47
Re: LSD diff's
From sydney
as far as i've been told the C20 housing is supposed to be the same as bluebird and R31 skyline which is also supposed to be the same as falcon, but only if its the borg warner with the lift out centre. ie, from the front. i have an lsd from an EB falcon but so far haven't had the time to try and fit it. but i have a vanette housing which is supposed to be the same. i got the centre for eighty bucks, but needs new clutch packs.
Posted on: 2004/11/24 1:26
Re: LSD diff's
From Wellington New Zealand
Squiggs I think you have been told wrong. The Falcon Borg Warner type 75 is a Salisbury style rear loading diff. Aussie market Nissans (Skyline) got them too but the C20s has H165 or H190 Nissan banjo front loaders. C20 A12s had the 165s and A15s got the 190.
Posted on: 2004/11/24 3:57
1200 coupe 1400 GX 5 speed
1200 coupe LHD peripheral port 12A rotary.
1200 ute
Sunny 310 SGX.
Re: LSD diff's
The A15 would be the C120, wouldn't it?
OK to answer my own question:
C20 - 1970-1978
C120 - 1979-1985
The C20 was named various things: Datsun Sunny Cab, then Nissan Cherry Cab, then Nissan Sunny Cab.
The C120 was called the Datsun Vanette or Sunny Vanette or Largo.
Posted on: 2004/11/24 6:18
Re: LSD diff's
From Taupo New Zealand
Well, not exactly, it's a little more complicated...
I bought a C120 once for the diff, hoping it would be a 4.875:1 H165 LSD. It had a Z20 engine and was like a velour lounge suited livingroom on wheels. The diff was about 6 inches or something wider than the stock 1200 diff, (Makes sense that it was called a Largo I guess...) 4.11:1, and non-LSD.I swapped it with a wrecker for a C20 diff, which was about 4" or so wider, H165 4.1:1, non-LSD. I have also seen H190s in C20s as stirlingmac mentioned.
Feral has a very useful microfiche that he has posted before about what axle/ratio came in which vehicle, if someone more computer savvy could dig it out it might be helpful?
Like anything to do with Japanese cars, it's a whole lot more complicated than it first seems...
Posted on: 2004/11/24 9:07
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
Re: LSD diff's
And to answer the original question, yes LSDs exist and are available new, but are quite pricey, around NZ$1300+ gst and shipping ex Japan.
There are rare as hens teeth secondhand, although rally-a-coupe posted recently that he had one in a disc braked housing for $1500. I PMed him asking if he still had it but haven't got a reply.
Posted on: 2004/11/24 9:13
1970 1200 coupe A15
1978 B310 SR16VE
Re: LSD diff's
Posted on: 2004/11/24 16:09
