From Fort Worth, Texas, USA
The simplest front suspension upgrade I have found is the stuff from a 210. Ive done it more than once and it all pretty much bolts right in. Get everything; struts, ball joints, lower arms, steering links (unscrew the link between the inner and outer ball joints on each side of the car), T/C rods, and whatever else I forgot. Basically, three nuts on top, one on the T/C rod, one nut and bolt on the crossmember, the steering link, and the brake line and she all falls in your lap. You need to use the 1200 upper mount and cut the springs to get the ride height back down to an acceptable level. I have also done a 510 (1980 HL-510, not an early '70s real 510) strut swap but it was a lot more work, if I remember correctly. Of course, what we in the states got as an HL-510 was called a Stanza elsewhere in the world, and the Stanza swap is pretty popular. You need to look at the geometry of the parts I guess. Either way you go will net you bigger struts, not to mention ones that you can actually find at the parts store, and slightly larger brakes. You'll need to ditch the 12" wheels, as if I needed to tell you that.
Posted on: 2002/6/6 14:36
