Lights not workin
From brisbane
Hey fellas. Lights are not workin. Was driving mt Cootha in the wee hrs of the mornin. I turned my lights off from outside the car with the engine still running (on the turbo timer) and they just didnt switch back on. The strange thing is I pulled it all to bits, found nothing wrong with it and put it back together and it worked. THEN that night lights workin fine; stopped for dinner, and they have not turned on since. The switch seems fine, fuse is ok, lamps light up when I give them charge. The only link not checked is the relay. It is really weird!
Does anyone in Brisso have a light switch they are not too attached to. I did a round of the wreckers today and they were all reamed to get dashes off.
Cheers fellas,
Mely
Posted on: 2005/4/1 9:11
Re: Lights not workin
From brisbane
The mystery continues. I chased the relay and it is fine. I replaced all the fuses, for lights, wipers, brakelights, ignition. So then the lights started workin again, but the parkers and tail lights stopped workin. Then I put an alligator clip across the light fuse and everthing worked as it should have. Then I drove to the servo to get a 20A fuse for the lights, and with that installed It went back to parkers and tail lights and no headlights!? Dunno fellas think I might get a sparky to rewire all the original datto stuff. It is too weird for me.
Take it easy fellas
Mely
Posted on: 2005/4/1 11:46
