« 1 (2)
Re: ute rearend bouncing like a bunny
From Warburton vic
As L18 b110 said get some good shocks if you can afford it use koni adjustables there a reasonable price. & make sure all you bushes are good. It shouldnt matter what bushes you use new rubber bushes wont give you any trouble but ware out a bit quiker
Posted on: 2005/4/27 12:54
From sydney
Talk to your local spring shop there are a few ways to treat axle tramp and they will be able to fix it for you.
This is what I did and mine bounced like a bastard.
All fixed now.
Posted on: 2005/4/27 12:59
From Victor, NY
You might want to try some traction bars.. My old Datsun P/U had the same problem and after replacing the shocks and getting only a bit better I put traction bars on and the bouncing stopped. They are fairly cheap and come with either bottom mount or top mount. I used the bottom mout type but wouldnt reccomend them as you lose a few inches of ground clearance.
Posted on: 2005/4/27 20:30
Quicksand - Victor, NY
From Brisbane
In my dato, ive got the exact same problem, really aggressive rear end bouncing as soon as u loose traction. Sounds like u guys have got some good ideas comming from past experisnces, sounds like a good idea to give it a go, ill let yas know the outcome of it when i get my licence back(in 6 months )
Cheers
Posted on: 2005/4/28 0:08
From Strand, South Africa
thanks for all your help guys and sorry for my late reply, my off day turned into a day madness .
i'll start stripping and shopping for parts, including a couple of new seats with headrests
Posted on: 2005/4/28 8:51
« 1 (2)
