Restoring body to that factory shine....
As my under loved wagon has been left in the sun for long periods of time and no TLC, the paint has slowly faded away to washy red/whit colour...
Now what would be the best way to restore this? I have trieed cut & polishing it and that worked well but is there a secret product/trick i should know about to doing this?
I cant do a respray as i dont have the $$ or time...So any help and info on what the best way and products to use would be great!!
Cheers
Dave
Posted on: 2005/4/29 0:00
Re: Restoring body to that factory shine....
From Toowoomba, australia
no real secrets use about 2000 2200 grit sandpaper and a good quality cut & polish compound. don't rush
Posted on: 2005/4/29 7:12
why go up and down when you can go round and round
From Melbourne, Australia
If you're nervous about usning the sandpaper try a "rougher" grade of cutting compound first. Then step up to the finer cutting compound followed by your favourite wax.
I don't recommend anything that claims to do two things at once. Ie wash and wax, or cut and polish. I think it's crap. You're better off buying the stuff that does one job properly. Once you are where you want to be with the paint shine, if you can keep applying the wax you won't need to continually cut it.
Posted on: 2005/4/30 4:30
From Feilding, New Zealand
Backfire is right. use the correct polish for the good you are doing.
dont forget the piant on the car will be thin so dont rub too hard.
you might even try useing a colour based polish after you have cut and before a plain polish.
good luck
Posted on: 2005/4/30 4:47
yeah i was thinking just buying a good quality 'cutting' compund and not going into the combined things...I do own lots of 2000grit paper (guitar body work) so that aint a problem. If i do use the paper there isnt any prep needed, just jump right into sanding it back?
And ive got to patch a few areas up with paint (rust areas mainly so ill have to blend the colour in a bit)....any ideas?
Cheers
Dave
Posted on: 2005/5/1 11:38
From Northern NSW
hey mate ive been in and out of detailing for a while and the best thing u can do is get turtle wax.....give the car a thorough polish apply in small circles.......then get maguires "wet look" apply that #### man and u'll be laughin
Posted on: 2005/5/1 12:13
dato ute (see avatar)
a14 blowthrough turbo motor
Import Auto Parts
For all your jap performance parts and accessories
pm for availabilty and quotes
